Continuous uniform meshing
Dear Sir,
In my model the various geometries have separate meshing. I want to know if there is a way to make the meshing continuous , meaning there is no discontinuity at the boundary of a geometry ( object ). I want the entire model to have continuous and uniform geometry of the same size.
Thanking you in advance,
Vijay.
1 Reply Last Post 1 oct. 2012, 15:42 UTC−4
Posted: 1 decade ago 1 oct. 2012, 15:42 UTC−4
from what I interprete (but I might be wrong ;) is either you have used Assembly and not UNION mode in the geoemtry, which multiplies the common boundaries between the domains, and allows for very differet mesh per domain, without "continuity" over common borders, just as it does NOT propose default continuous flow over these boundaries, you need to define this manually,
Or you are using the default "Union" mode and it's simply that the default mesh is such that you get a very large dispersion. You can try a custom mesh with the same value for the max and the min size, but, it might make the mesher fail as its not always possible to get the same mesh size everywhere ;)
Hi from what I interprete (but I might be wrong ;) is either you have used Assembly and not UNION mode in the geoemtry, which multiplies the common boundaries between the domains, and allows for very differet mesh per domain, without "continuity" over common borders, just as it does NOT propose default continuous flow over these boundaries, you need to define this manually, Or you are using the default "Union" mode and it's simply that the default mesh is such that you get a very large dispersion. You can try a custom mesh with the same value for the max and the min size, but, it might make the mesher fail as its not always possible to get the same mesh size everywhere ;) -- Good luck Ivar
