Importing an image and creating a parametric surface
Hello fellow Comsolers...
It's been a while since I have been on here, but I am back!
I am having quite a basic problem with creating a parametric surface from an image.
I create a global definition which is my image (at the moment I am doing a very basic image which is a white square with a black smaller square in the middle). I import the image and when I plot it, I can see that the image is coming into Comsol without any problems.
However, when I try to create a parametric surface I get confused and I'm not too sure what each of the parameters means.
Does anyone here have a working image to parametric surface example I could have a look at please? It can be very basic or more complicated. I would just like to see the image to parametric surface feature working.
Thanks very much for the help,
Rob
3 Replies Last Post 26 nov. 2012, 15:26 UTC−5
Posted: 1 decade ago 28 sept. 2012, 12:01 UTC−4
Hey everyone...
I have an image which works and I was thinking of creating a guide showing how to import an image and create a surface from it, and then create a geometry from it. Would that be of any use to anyone on here?
Rob
Hey everyone... I have an image which works and I was thinking of creating a guide showing how to import an image and create a surface from it, and then create a geometry from it. Would that be of any use to anyone on here? Rob
Posted: 1 decade ago 28 sept. 2012, 12:58 UTC−4
Sure, go ahead!
Sure, go ahead!
Waranatha Abeygunasekara
Posted: 1 decade ago 26 nov. 2012, 15:26 UTC−5
Hi Rob,
I need to do exactly same. I need to convert an image in to a surface and then in to a geometry and still haven't figured out how to do it . Please do post your guide, it would be a great help for me.
Waranatha.
Hi Rob, I need to do exactly same. I need to convert an image in to a surface and then in to a geometry and still haven't figured out how to do it . Please do post your guide, it would be a great help for me. Thanks, Waranatha.
