[Error] Failed to find consistent initial values - multiple electrode materials
Posted 8 oct. 2022, 05:08 UTC−4 Battery Design, Electrochemistry, Materials, Modeling Tools & Definitions, Studies & Solvers, Modeling Workflow, Physics Interfaces Version 6.0 0 Replies
I am trying to simulate a lithium-ion battery with multiple intercalating cathode materials. I am using NMC 811 and LFP as the cathode materials in this model. I have followed the procedure as it is described in the COMSOL documentation: Lithium-ion battery with multiple intercalating electrode materials. The main difference is in the material I have used.
The figure below shows the "model builder" of my model:
I would be pleased to share the mph file if anyone could possibly sort this out.
The following is the displayed error upon solving:
*Feature: Time-Dependent Solver 1 (sol1/t1) Failed to find consistent initial values. Undefined value found. Undefined value found in the equation residual vector. There are 97 degrees of freedom giving NaN/Inf in the vector for the variable comp1.cl. at coordinates: (0), (2.62047e-06), (5.24094e-06), (7.86141e-06), (1.04819e-05), ...
There are 28 degrees of freedom giving NaN/Inf in the vector for the variable comp1.liion.csaddm1. at coordinates: (0), (0), (0), (0), (0), ...
There are 22 degrees of freedom giving NaN/Inf in the vector for the variable comp1.liion.cspce1. at coordinates: (0), (0), (0), (0), (0), ...
There are 28 degrees of freedom giving NaN/Inf in the vector for the variable comp1.liion.cspce2. at coordinates: (0), (0), (0), (0), (0), ...
There are 97 degrees of freedom giving NaN/Inf in the vector for the variable comp1.phil. at coordinates: (0), (2.62047e-06), (5.24094e-06), (7.86141e-06), (1.04819e-05), ...
There are 97 degrees of freedom giving NaN/Inf in the vector for the variable comp1.phis. at coordinates: (0), (2.62047e-06), (5.24094e-06), (7.86141e-06), (1.04819e-05), ... Last time step is not converged.*
Hello Parthiv K
