Add parameter to parametric sweep after Parametric Solution already exists
I have the same question as in the unanswered discussion above.
Suppose I have solved a parametric sweep simulation over the variable a = (1,3,5).
After checking my results, I want to add the parameters a = (2,4) to my sweep without resolving the existing solutions (1,3,5). Is there an easy way to do this?
My work-around is to create a second parametric sweep that contains only the new parameter setup, and later merge the two solutions. But this is a tedious process.
Thanks a lot for your help!
0 Replies Last Post 6 oct. 2022, 08:53 UTC−4
Hello Julius Harms
