Jeff Hiller
COMSOL Employee
2 years ago
21 juin 2022, 09:25 UTC−4
Updated:
2 years ago
21 juin 2022, 09:50 UTC−4
Hello CJ,
You can create a helix with arbitrary cross-section by first drawing the cross-section in a workplane and then sweeping that cross ection along a parametrized curve. You will find several discussions in this Discussion Forum where this has been discussed, including some example files provided by other users. Just search the Discussion Forum for "helix".
I don't quite understand your second question. It seems to also relate to geometry creation, so I would suggest browsing through Chapter 7 of the COMSOL Multiphysics Reference Manual, or viewing the video on geometry creation in the Learning Center
Jeff Hiller
Hello CJ,
I don't quite understand your second question. It seems to also relate to geometry creation, so I would suggest browsing through Chapter 7 of the COMSOL Multiphysics Reference Manual, or viewing the video on geometry creation in the [Learning Center](https://www.comsol.com/learning-center)
2 years ago
21 juin 2022, 22:01 UTC−4
Updated:
2 years ago
22 juin 2022, 09:32 UTC−4
Hello Jeff
Thank you for your timely reply.
In fact, I had try to draw a the cross-section in a workplane and then sweeping that cross ection along a parametrized curve. But I failed.
Thank you for your understanding.
Best wishes
CJ
Hello Jeff
Best wishes
CJ
Jeff Hiller
COMSOL Employee
2 years ago
22 juin 2022, 08:27 UTC−4
Updated:
2 years ago
22 juin 2022, 10:05 UTC−4
If your license is eligible for technical support from COMSOL, and you would rather not share the model file on the Discussion Forum, please use the support portal to contact the support team. They'll able to help you.
Jeff Hiller
2 years ago
22 juin 2022, 09:51 UTC−4
Hello,Jeff
I see, Also thank your advice,
Best
CJ
Hello,Jeff
Best
CJ
