2 years ago
14 juin 2022, 02:42 UTC−4
If you are using the Maxwell Stress tensor to cacluate force, this is very mesh dependant and you will need to ensure the boundaries on the domain for which you wish to calculate the force have a sufficiently fine mesh, (possibly using boundary elements).
Also, sharp corners can cause inaccuracies, consider filleting any sharp edges in the calculation domain.
Also, if you are using symmetry in your model, you will need to multiply the calculate force by 2/4/8 depending on the symmetry you have used in the model.
Mark
Mark
2 years ago
26 juin 2022, 08:32 UTC−4
Mark
Thank you for your answer, I think the calculation may be inaccurate due to the coupling through the surface current density in the magnetic field
>Mark
