Hello Aaron Sassoon
11 oct. 2013, 00:10 UTC−4
I am trying to do the same thing with micropump model. Also getting stuck with the FSI physics
11 oct. 2013, 05:31 UTC−4
I think you fall into a trap that you have to use Piezoeletric Devices and Fluid-Structure Interaction.
As you know, there is no Piezoelectric Material Domain Settings in Fluid-Structure Interaction. This is the first problem you had. So, to consider both Linear Elastic Material and Piezoelectric Material Domain, you need to change all applications. These are,
1. Piezoelectric Devices to consider both Cu and PZT-5H
2. Laminar Flow to consider Air
3. Moving Mesh to consider both air and solid
4. Boundary ODEs and DAEs to consider solid velocity
5. Time Dependent Solver
And, physics couplings are,
1. air acts on the surface of solid : use the boundary load
r-term : spf.T_stressr*dvol_spatial/dvol
z-term : spf.T_stressz*dvol_spatial/dvol
2. in fluid, wall : moving wall : solid velocity from ODEs settings on the interface of the air/solid
3. define the solid velocity in ODEs. if solid displacement is u and w, solid velocity is ut and wt where t means time.
4. In moving mesh, use 1. prescribed deformation to consider solid displacement, 2. prescribed mesh displacement to consider solid displacement & axial symmetry.
thanks.
thanks.
4 déc. 2013, 01:14 UTC−5
Hi Tae,
I have a very similar situation. can you please upload the finished model here to get a better understanding of what you just mentioned ?
much appreciated.
FM
Hi Tae,
much appreciated.
FM
20 févr. 2014, 10:25 UTC−5
plz plz help me for modeling synthetic jet actuator in comsol 3.5a . i am new in comsol 3.5a . if anybody will help me so that i seek all tit bits of comsol . i requested you all people plz help me . i m now frustating fr last 2 years.
thanks n requested to all my friends .....
10 years ago
21 juil. 2015, 02:39 UTC−4
Hi Tae,
you are saying that boundary ODEs and DAEs interface has to be used to calculate solid velocity.But i can't understand how to calculate .what will be the equation i have to use ....what will be the source term,mass coefficient,damping coefficient in distrbuted ODEs 1 setting window.plz help...
Hi Tae,
8 years ago
31 août 2017, 22:37 UTC−4
Could you give more information. I am puzzled.
