limitations of number of data in table or result.
I am using the transient solver in RF modual, and recording the time-varying electric field.
For example, I have the following setteings:
Comsol is set to record the electric field at a given point every 1fs starting from 0 to 20,000fs.
Then, after simulation, I would suppose to have 20,000 data points.
However, it seems that there is a limitation on the maximun number of stored data numbers, only the latest 10,000 data are recored, and all the values before that are erased. Under this situation, when I plot electric field E versus time t, I only get 10,000 points instead of 20,000.
Can anyone help me to figure this out, since I need a long data sequence to do further data analyzing. I really appreciate for your help. Thanks.
2 Replies Last Post 31 juil. 2012, 11:20 UTC−4
Posted: 1 decade ago 30 juil. 2012, 14:28 UTC−4
I usually use Results-Export-Data. It easily gives me 1,000,000 points
Posted: 1 decade ago 31 juil. 2012, 11:20 UTC−4
Hi Alexander,
It really helps, thank you.
Hi Alexander, It really helps, thank you.
