apply ac voltages of different frequencies to two parts of one geometry?
Hello
I'm going to apply an ac voltage from electric current.
How do you apply ac voltages of different frequencies to two parts of one geometry?
<I used waveform to indicate Vac = Vinsin(2pift). it applied two parts at different frequencies(using time domain) However, particles do not move in the particle tracing part. (but when I used the frequency domain, it was calculated>
I need your help.
best regards,
1 Reply Last Post 18 mars 2022, 11:17 UTC−4
Posted: 2 years ago 18 mars 2022, 11:17 UTC−4
make sure the time stepping in the time dependent solver resolves the waveform. You will need to use manual time steps instead of the automatic default stepping.
Cheers Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
Hi, make sure the time stepping in the time dependent solver resolves the waveform. You will need to use manual time steps instead of the automatic default stepping. Cheers Edgar
