Error on Cluster Computing
Posted 5 mars 2022, 01:56 UTC−5 Low-Frequency Electromagnetics, Heat Transfer & Phase Change, Cluster & Cloud Computing Version 5.3a 0 Replies
I am trying to run a transient, 3D thermal problem in COMSOL. The input is the heat loss calculated in the 2D axisymmetry model in another component of the same file. This loss is mapped in 3D geometry using a general extrusion.
When I run this file on Windows desktop, it runs fine. However, when I try to run it on the cluster facility, the error pops up saying 'Internal error in solution merge'. The log file is attached here. I am using v5.3a.
What is the issue and how should I fix it?
Hello Pranoti Raut
