The Heat capacity at constant pressure of materials is defined by interpolation function
Posted 1 mars 2022, 09:10 UTC−5 Heat Transfer & Phase Change 2 Replies
Hello, I am using interpolation functions to define the Heat capacity at constant pressure of materials. The specific heat capacity of a material varies with temperature. But the call to this function (heat_cp) always shows yellow and says: unknown variable heat_cp. However, I checked that the units of the function were J/(kg*K) and did not forget the definition. How can I correct this mistake. Any help would be helpful.
