How to know when the system reaches steady state?
I am solving a "heat transfer in solids" problem (only conductive heat transfer) with time-dependent solver. Heat dissipation is pulsed and on/off periods are in microseconds.
I've solved the model with stationary solver by taking average of the heat dissipation. For instance, heat dissipation is 100W with a duty cycle of 40%, which makes 40W average heat dissipation. By solving the system with 40W heat dissipation by using stationary solver, I have the value for steady state.
However, when I try to solve the system with real on/off heat dissipation value, I need to use time dependent solver. However, temperature increase is extremely slow since pulse time is around 20 microsecs on/30 microsecs off. If the system reaches steady state after 10 seconds, for instance, it makes 10000000 microsecs which requires incredibly high number of timesteps to solve.
How do I determine or estimate total time for the system to reach steady state? Any suggestions? Thank you for reading and help.
Sincerely,
Orcun
3 Replies Last Post 17 févr. 2022, 08:50 UTC−5
Posted: 2 years ago 17 févr. 2022, 04:33 UTC−5
Orcun,
I would suggest to run a time dependent study with constant average heat dissipation.
Cheers Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
Orcun, I would suggest to run a time dependent study with constant average heat dissipation. Cheers Edgar
Posted: 2 years ago 17 févr. 2022, 06:02 UTC−5
Dear Edgar,
Thank you for your suggestion. I will be trying this to see when the model reaches S.S.
Best Regards,
Orcun
Dear Edgar, Thank you for your suggestion. I will be trying this to see when the model reaches S.S. Best Regards, Orcun
Posted: 2 years ago 17 févr. 2022, 08:50 UTC−5
Updated: 2 years ago 17 févr. 2022, 11:47 UTC−5
Hello Orcun,
You can also get a general feel for the order of magnitude of the time it will take for your system to reach steady state by considering that the penetration depth in a thermal conduction problem is proportional to sqrt(kt/(rhoCp)) and the time length scale is tau=rho * Cp * L^2 / k (See this old thread for details). For many problems where all the sinks and sources are on the boundaries, this provides a decent estimate, with steady state being reached -for practical purposes- in a few taus.
Jeff Hiller
Hello Orcun, You can also get a general feel for the order of magnitude of the time it will take for your system to reach steady state by considering that the penetration depth in a thermal conduction problem is proportional to sqrt(k*t/(rho*Cp)) and the time length scale is tau=rho * Cp * L^2 / k (See [this old thread](https://www.comsol.com/forum/thread/16808/weird-problem-in-comsol-tmeperature-measurment?last=2011-04-11T20:06:31Z) for details). For many problems where all the sinks and sources are on the boundaries, this provides a decent estimate, with steady state being reached -for practical purposes- in a few taus. Best, Jeff
