Can "research" perform the following functions&Phase change problem
Is it possible to add two "studies" in COMSOL 5.6 and use the results of the first study as the initial conditions for the second study? And the physical fields used in the two studies are not the same.I want to do the whole transient process of melting and vaporization of the mass inside the "heat pipe" from the solid state to the gaseous state. I would like to do it in two studies. Or is there any other better way to complete this process?
0 Replies Last Post 14 févr. 2022, 22:13 UTC−5
Hello 文斌 刘
