3D induction heating meodelling
I'm a beginner on Comsol and I'm trying to produce a 3d induction heating model. I did a 2d previously and I was able to run it without problems. But on the 3d I have the following error message :
- Feature: Time-dependant Solver 1 (sol/t1)
- Error: Failed to find initial values
- Comsol assertion failure.
Could someone tell me if the 3d requires more boundary conditions or if I might miss-understood something?
Thank you!
Patrice G.
7 Replies Last Post 12 oct. 2012, 03:29 UTC−4
Hello Patrice Gouin
Posted: 1 decade ago 11 oct. 2012, 03:29 UTC−4
I am also doing Induction hetaing in §d work space, m also geting a same error.
Could you able to find any solution? please let me know know.
Thank you
Hello, I am also doing Induction hetaing in §d work space, m also geting a same error. Could you able to find any solution? please let me know know. Thank you
Andrea Ferrario COMSOL Employee
Posted: 1 decade ago 11 oct. 2012, 08:08 UTC−4
Patrice, Chirag,
are you using version 4.0a? Please try with a more recent version and the error should disappear.
Andrea Ferrario
Electromagnetics Group
COMSOL AB
Patrice, Chirag, are you using version 4.0a? Please try with a more recent version and the error should disappear. -- Andrea Ferrario Electromagnetics Group COMSOL AB
Posted: 1 decade ago 11 oct. 2012, 08:48 UTC−4
hi all,
Now I'm using Comsol 4.2.
Instead of having an error, the model just don't give any answer, but when I added fillet to my sharp edge it works. Unfortunately, the simulation don't give the same results I obtained experimentally.
Is someone knows if we have to put an initial current higher which will stabilize by itself?
Pat G.
hi all, Now I'm using Comsol 4.2. Instead of having an error, the model just don't give any answer, but when I added fillet to my sharp edge it works. Unfortunately, the simulation don't give the same results I obtained experimentally. Is someone knows if we have to put an initial current higher which will stabilize by itself? Pat G.
Posted: 1 decade ago 11 oct. 2012, 10:21 UTC−4
do not forget that sharp edges are singularities in many physics, as you do not know how to define a x-y-z spatial derivative on such a vertex
Also v4.0 was the first one out not really ironed out either, I strongly suggest to rebuild your model fully in a newer version (not jsut load in and "translate" this applies particularly for the pre 4.1, as backward compatibility is far better for the latest versions
Hi do not forget that sharp edges are singularities in many physics, as you do not know how to define a x-y-z spatial derivative on such a vertex Also v4.0 was the first one out not really ironed out either, I strongly suggest to rebuild your model fully in a newer version (not jsut load in and "translate" this applies particularly for the pre 4.1, as backward compatibility is far better for the latest versions -- Good luck Ivar
Posted: 1 decade ago 11 oct. 2012, 13:37 UTC−4
Hi all,
I'm trying to upload my model in this forum but it's too big. Does someone know how to save it without the solution?
Thank you
Pat G.
Hi all, I'm trying to upload my model in this forum but it's too big. Does someone know how to save it without the solution? Thank you Pat G.
Posted: 1 decade ago 11 oct. 2012, 15:48 UTC−4
indeed yes, check the forum more regularly, or try a search ... Or even read the doc ;)
But if you go to (depends on version) edit clear all solutions edit claer all mesh then File reset history you should strongly reduce the model size. Anyhow one should always do this before uploading a model (at least in V4) as lse we will overload the forum disk with not very useful data. (do not DELETE, just clear
Some issues: in older v3.5a you loose your mesh, and the meshing history is NOT stored so perhaps try to NOT clear the mesh for v3.5a
for complex conditional and copled sovler sequences, these might reset their initial pointer settings in v4.3.
Workaround, once cleared all solutions, generate the initial conditions of the first "master(s)* solving sequences, from which the unsolved variables are loaded from, then check the logic of the initial conditions of all solvers, then delete the mesh and save. (this workaround only concerns complex linked solver sequences, and probably will behave better & easier from next patch, at least that is what I understood from "support" on my inquiry). Anyho I strongly suggest that you get a more mature version than 4.0.
Hi indeed yes, check the forum more regularly, or try a search ... Or even read the doc ;) But if you go to (depends on version) edit clear all solutions edit claer all mesh then File reset history you should strongly reduce the model size. Anyhow one should always do this before uploading a model (at least in V4) as lse we will overload the forum disk with not very useful data. (do not DELETE, just clear Some issues: in older v3.5a you loose your mesh, and the meshing history is NOT stored so perhaps try to NOT clear the mesh for v3.5a for complex conditional and copled sovler sequences, these might reset their initial pointer settings in v4.3. Workaround, once cleared all solutions, generate the initial conditions of the first "master(s)* solving sequences, from which the unsolved variables are loaded from, then check the logic of the initial conditions of all solvers, then delete the mesh and save. (this workaround only concerns complex linked solver sequences, and probably will behave better & easier from next patch, at least that is what I understood from "support" on my inquiry). Anyho I strongly suggest that you get a more mature version than 4.0. -- Good luck Ivar
Posted: 1 decade ago 12 oct. 2012, 03:29 UTC−4
Hello Patrice,
I am using latest version of comsol, and the error was like following:
Failed to find a solution for the initial parameter.
Divergence of the linear iterations.
Please guide me if anyone having an idea about it.
It would be greatful if you upload your model.
Thanks a lot.,
Chirag Oza
Hello Patrice, I am using latest version of comsol, and the error was like following: Failed to find a solution for the initial parameter. Divergence of the linear iterations. Returned solution is not converged. Please guide me if anyone having an idea about it. It would be greatful if you upload your model. Thanks a lot., Chirag Oza
