Measure the mass of a domain
Good day May i ask is there any method to measured the mass of a domain? For example, i build a sphere in COMSOL and and need to know the mass of the sphere.
Thanks in advance
2 Replies Last Post 10 janv. 2022, 03:49 UTC−5
Posted: 3 years ago 7 janv. 2022, 09:25 UTC−5
Define a domain integration and integrate the density of the domain. If you integrate 1 you get the volume.
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
Magnus Ringh COMSOL Employee
Posted: 3 years ago 10 janv. 2022, 03:49 UTC−5
Updated: 3 years ago 11 janv. 2022, 10:46 UTC−5
Also, check out the Mass Properties node under Component>Definitions, where you can define variables for the mass, volume, center of mass, and moments of inertia.
Magnus
Hi, Also, check out the **Mass Properties** node under **Component>Definitions**, where you can define variables for the mass, volume, center of mass, and moments of inertia. Best regards, Magnus
