NOx Reduction in a Monolithic Reactor
Posted 1 janv. 2022, 03:57 UTC−5 Chemical, Chemical Reaction Engineering 0 Replies
Why in the model NOx Reduction in a Monolithic Reactor, the 3D version, we calculate the concentration of the inlet streams as inlet molar flow rate devided by volumetric flow rate: for example for the flow of NO "F_NO_in/vrate", while "vrate" is defined as "v_av*A" in the global parameters and not corrected for the actual cross section area of the reactor "A_in"?
Hello Yehia El Shazly
