Equation based modeling (General form PDE)
Posted 13 nov. 2021, 01:44 UTC−5 Fluid & Heat, Computational Fluid Dynamics (CFD), Equation-Based Modeling Version 5.6 0 Replies
Hi all
I've been trying to simulate the electro magnetic effect on fluid flow for a cube geometry with spherical hole inside. momentum equation works fine. I've written the continuity equation with periodic boundary conditions on all faces (in pairs). But when I try and run the program, I get an error message reading:
*" - Feature: Stationary Solver 1 (sol1/s1) Failed to find a solution. General Form PDE 2 Singular matrix.
There are 41446 void equations (empty rows in matrix) for the variable comp1.p1. at coordinates: (-0.475897,-0.43475,-0.5), (-0.449108,-0.473212,-0.475897), (-0.470065,-0.399854,-0.427757), (-0.476182,-0.4113,-0.36878), (-0.423205,-0.440337,-0.47384), ...
and similarly for the degrees of freedom (empty columns in matrix). In General Form PDE 2: Returned solution is not converged. Not all parameter steps returned. "
Does anyone know what causes this, and how I can avoid it? I couldn't find anything on the website.
Hello Promasree Majumdar
