Error message
Hi.
When I have created my model, when I have computed it an error message has appeared.
The text was : "Failed to find consistent initial values.
Last time step is not converged."
Someone can help me to find a solution to this problem?
Thanks.
2 Replies Last Post 24 sept. 2012, 19:25 UTC−4
Posted: 1 decade ago 3 juil. 2012, 08:54 UTC−4
Sorry cannot help much, but that means that your initial conditions are too far away from the final results, think over your model, give a best engineering guess of the dependent variables for the solved case (mostly better tha all "0" and try that as initial conditions, often it helps
And check: is the mesh compliant with the expected model results ?
Hi Sorry cannot help much, but that means that your initial conditions are too far away from the final results, think over your model, give a best engineering guess of the dependent variables for the solved case (mostly better tha all "0" and try that as initial conditions, often it helps And check: is the mesh compliant with the expected model results ? -- Good luck Ivar
Posted: 1 decade ago 24 sept. 2012, 19:25 UTC−4
I had that same error and was able to fix it by changing the time step.
Go to Study> Solver Configurations> Solver 1> Time-Dependent Solver 1> Time Stepping (in the Time-Dependent Solver window) and change the Initial Step value (make it smaller by at least 1 order of magnitude.)
And this should solve it!
Good Luck
Kelley
I had that same error and was able to fix it by changing the time step. Go to Study> Solver Configurations> Solver 1> Time-Dependent Solver 1> Time Stepping (in the Time-Dependent Solver window) and change the Initial Step value (make it smaller by at least 1 order of magnitude.) And this should solve it! Good Luck Kelley
