Multiphysics: RF Electromagnetic Waves under the influence of Magnetic Field Created by a Current Carrying Wire
I have a multiphysics problem. I can't figure out how to combine the two physics.
What I want to do is to solve RF EM waves (eigenfrequency) for a certain geometry (I prefer to use a torus therefore a 3D geometry) under the influence of a magnetic field created by a current carrying wire. I have the two physics (Magnetic Fields and Electromagnetic Waves) in my model. I can solve the two problems seperately, no problem.
But how can I make the EM Wave study to use the magnetic field created by the Magnetic Fields study in the solution?
Thanks.
1 Reply Last Post 2 août 2012, 08:44 UTC−4
Hello Huzeyfe Yilmaz
Posted: 1 decade ago 2 août 2012, 08:44 UTC−4
I am also experiencing some difficulties in combining two physics.
I am building a model for a SAW device.
I tested it using the "Piezoelectric Device" physics and I was able to see the admittance and other parameters.
Now, I want to obtain the S parameters. I introduced the "Electromagnetic Waves" physics and performed
some settings for it: added the ports and periodic conditions.
I started the simulations, but the parametric solver remains stuck around 20%.
Has any of you done this kind of simulation?
Do I need to operate some settings in order to get the two physics to work together?
Am I missing something?
Thank you,
Catalin B.
Hello, I am also experiencing some difficulties in combining two physics. I am building a model for a SAW device. I tested it using the "Piezoelectric Device" physics and I was able to see the admittance and other parameters. Now, I want to obtain the S parameters. I introduced the "Electromagnetic Waves" physics and performed some settings for it: added the ports and periodic conditions. I started the simulations, but the parametric solver remains stuck around 20%. Has any of you done this kind of simulation? Do I need to operate some settings in order to get the two physics to work together? Am I missing something? Thank you, Catalin B.
