Heat of Vaporization of Water
Posted 7 oct. 2021, 17:05 UTC−4 Fluid & Heat, Heat Transfer Version 5.6 0 Replies
Hi everyone, I am trying to solve the evaporation of water problem in Comsol but since the Heat of vaporization is strongly dependent on the temperature of the surface, I need temperature-dependent properties for water. All material properties are from the library but I couldn't understand whether the Heat of vaporization is a function of temperature or not.
If it is temperature dependent, is there any way I can see its function or how can I define this property in Comsol? Thanks a lot, Göksel
Hello Goksel
