applyingfrequency
can i directly apply frquency to the model? how?
1 Reply Last Post 20 juin 2012, 15:31 UTC−4
Posted: 1 decade ago 20 juin 2012, 15:31 UTC−4
it depends what you want to do: if you want to analyse a transient situation you should use a time stepping and define your loads or other BC's with a time varying equation.
but if you have a steady state oscillation (harmonic response) use the frequency domain solvers which does a development in omega and omega square, you define the frequency or frequency span/range in the solver setting.
Check the equations to understand how the equations look like in time series and frequency sweep solver modes
Hi it depends what you want to do: if you want to analyse a transient situation you should use a time stepping and define your loads or other BC's with a time varying equation. but if you have a steady state oscillation (harmonic response) use the frequency domain solvers which does a development in omega and omega square, you define the frequency or frequency span/range in the solver setting. Check the equations to understand how the equations look like in time series and frequency sweep solver modes -- Good luck Ivar
