Hello Tilmann John
4 sept. 2012, 13:44 UTC−4
you should define your inlet and outlet-boundaries. The selection is empty. I see, that you have chosen the hmnf-diffusor example. I did that too at first place. But the example is very special. You should chose a Material for the liquid. Look out that you take the right properties of the material, because there are two types (basic and ideal gas).
I had some help from the support to get my Laval-nozzle to work:
1. CFL-number:
You find this by clicking your "High Mach Number Flow 1" physics node and
then go to the "Advanced Settings". I have changed the default settings for
the second "ramp up" to "if(niterCMP>=260,40*1.3^min(niterCMP-260,9),0)"
and divided the entire expression for CFL by 10.
The CFL-number controls the "pseudo-timestepping", that is a iterative
development of the final solution using the iteration steps as
"pseudo-timesteps". The CFL-number is the step-width. And it is a local
variable, as it is dependent on the local mesh size. So at parts of the
mesh with small elements, "pseudo-time" will run slower - which is a good
thing, because at those parts you are probably expecting high gradients.
Nevertheless you should ramp this CFL-number up to higher values at some
points during your solution process to get a final solution in decent time.
The default settings ramp the CFL-number by using if-operators. But you
could enter any function using the variable "niterCMP", which is the
iteration number.
2. Finer Mesh:
I used a swept mesh of blocks for the rectangular part in the middle of
the geometry, which is a efficient way of meshing for those "structured"
regimes.
3. Isotropic Diffusion:
You find this in the "High Mach Number Flow 1" physics node in
"Inconsistent Stabilization". This is really inconsistent - you typically
get a mass loss due to this additional diffusion term. But your solution
will be very smooth and therefore convergence better. After getting a
solution with isotropic diffusion you can use that solution as initial
values for another study. In that study you should lower the isotropic
diffusion value to zero, then it will be disabled.
In general: To get your model to convergence you should lower the
CFL-number, ramp it up at later iteration point and refine the mesh at
parts of high gradients. During solving you should watch the "plot while
solving plot" for the velocity, which you activate at "Study>Solver
Configurations>Solver>Stationary Solver>Segregated Solver" -> "Results
while Solving".
1. CFL-number:
iteration number.
2. Finer Mesh:
regimes.
while Solving".
