Contact Impedance and Heat Transfer
I'm modelling two hangerbars (Electrowinning) and a busbar, and I want to calculate the heat produced by the contact between the hangerbar and the busbar. It works, until I introduce the heat transfer model. Apparently, the Contact Impedance from the AC/DC model doesn't work with the Heat Transfer, and I can't calculate the power losses in the contact. I have to say that the model gives me a result, but doesn't consider the power losses in the contact area.
One way to solve this it's making a solid contact area, as a new domain, but I want to work only with those areas (boundaries) and not a hall domain.
Can someone help me with this, or pointing to an easier way to solve this particular problem?
Thanks.
Jorge Henriquez
2 Replies Last Post 31 mai 2012, 16:09 UTC−4
Posted: 1 decade ago 31 mai 2012, 02:12 UTC−4
I'm not sure it's this but it might be that you need to introduce the surface contact dissipated power explicitely by a surface heat source in the HT
Have you checked carefully the Equation view. With multiphysics one need to carefully check all elements, in particular at the interfaces
Hi I'm not sure it's this but it might be that you need to introduce the surface contact dissipated power explicitely by a surface heat source in the HT Have you checked carefully the Equation view. With multiphysics one need to carefully check all elements, in particular at the interfaces -- Good luck Ivar
Posted: 1 decade ago 31 mai 2012, 16:09 UTC−4
Thansk, but that wasn't it. I solve it changing the surface to a domain, and it works fine.
Thanks for the help anyway.
Thansk, but that wasn't it. I solve it changing the surface to a domain, and it works fine. Thanks for the help anyway.
