29 mai 2012, 09:44 UTC−4
I'm not sure I undertand what you mean, if you define a 2D cut line you must give the equation in x,y hence you can invert it.
You can also change the plot x-Axis expression, see the line graph node tabs
29 mai 2012, 12:41 UTC−4
I am looking at the bending of a beam in 2d. I made a cut line 2d through the beam and plotting the strain as a function of the arclength. I want to find the x-value where the strain is zero. How is that possible?
thanks
thanks
29 mai 2012, 14:59 UTC−4
I might be making a simple problem complicated, but if you are looking for a zero of a existing variable you can express that variable^2 (squared) along your cut line and ask for the minimum with a min() operator, then the
"min(varable^2,x)" and "min(variable^2,y)" etc will give you the coordinates of the minimum.
Check the doc, search for "min(" the way to get the coordinates is explained in a few places)
At least that works for a Domain and boundary, so why not for a Cut line ?
