Coupling Level Set, 2 phases flow and Non newtonian flow applications
Hello everybody,
I would like to model a flow of two non Newtonian fluids in a channel with the Level Set method.
Should I couple the "Level Set" application or the "Two-Phase Flow, laminar, Level Set" application with the "Non Newtonian Flow" application ?
How should I proceed to couple the variables ? In fact, in the Level Set method, u is the velocity of the fluid. How and where can I define this u as the velocity of one fluid or the other according to phi ?
Thank you for your help,
Erwan
3 Replies Last Post 9 mai 2011, 16:56 UTC−4
Posted: 1 decade ago 1 févr. 2010, 15:29 UTC−5
If you have any idea, I would really appreciate your help.
Thank you
If you have any idea, I would really appreciate your help. Thank you
Posted: 1 decade ago 4 févr. 2010, 10:40 UTC−5
The recent news article in the multiphysics blog may help you in this regard.
www.comsol.com/community/blogs/multiphysics/33/
The recent news article in the multiphysics blog may help you in this regard. http://www.comsol.com/community/blogs/multiphysics/33/
Posted: 1 decade ago 9 mai 2011, 16:56 UTC−4
I want to do the same thing. did you find any way to do that?
I appreciate it so much if you let me know , I am stuck in it :(
thanks
Hi I want to do the same thing. did you find any way to do that? I appreciate it so much if you let me know , I am stuck in it :( thanks
