Plotting the movement of isothermal surface over time
I ran time-dependent study on the heat transfer of a 3d object. I could plot the the surface at a partucular temperature at different timepoints individually. I'm wondering if there's a way I could combine all these timepoints into one graph. So I could see the movement of one temperature surface moving within the 3D object, and the surfaces are labeled with time.
Thanks!!
1 Reply Last Post 15 avr. 2021, 11:07 UTC−4
Posted: 3 years ago 15 avr. 2021, 11:07 UTC−4
Lillian,
not sure if such a static plot is possible and if it wouldn't get a little messy. I have very good experience with using animations to visualize such time-dependent phenomena.
Also any audience is mostly very impressed by animations.
Cheers Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
Lillian, not sure if such a static plot is possible and if it wouldn't get a little messy. I have very good experience with using animations to visualize such time-dependent phenomena. Also any audience is mostly very impressed by animations. Cheers Edgar
