Solving model with several ModelNodes
I'm trying to build a model that contains several ModelNodes (sub-models). Each Node should have different properties (same geometry but I want to alter the mesh). The the Model should be solved at once.
My questions are:
How to set dependent variables (since the sub-models should not be coupled)?
How to access the solution for each ModelNode?
Are there some examples available (couldn't find anything about this in the Comsol 4.2a documentation)?
CS
2 Replies Last Post 11 mai 2012, 15:41 UTC−4
Posted: 1 decade ago 11 mai 2012, 01:31 UTC−4
it often becomes difficult to find your way like that but it's possible. When you add several times a physics the dependent variables get number increments by default V, V1 V2 for 3 EC physics etc
Hi it often becomes difficult to find your way like that but it's possible. When you add several times a physics the dependent variables get number increments by default V, V1 V2 for 3 EC physics etc -- Good luck Ivar
Posted: 1 decade ago 11 mai 2012, 15:41 UTC−4
thank you that was very helpful, now I'm sure that it works :)
CS
Hi, thank you that was very helpful, now I'm sure that it works :) Best, CS
