Changing variables between time steps
Hi everyone,
I have a studied how the standard time dependent solver works by checking the check box "show results while solving" then I can see the all time steps update one after another. I have noticed that the solver sometimes go back and recalculates a time step.
Now my question is; can I add my own conditions that will be checked after each time step and if they are fulfilled, change a variable, recalculate that time step and then continue as normal?
I run Comsol 4.2 and have Livelink to Matlab etc. if that helps!?
Stefan
5 Replies Last Post 30 juil. 2012, 02:18 UTC−4
Hello Stefan Sjökvist
Posted: 1 decade ago 11 juin 2012, 19:07 UTC−4
have you found any solution to this yet?! I encounter the same problem. I like to have access to solution at each time-step, change some parameters at that step and go to the next. If you could come up with some hints please let me know. Thanks.
Posted: 1 decade ago 12 juin 2012, 02:25 UTC−4
Unfortunately not. At the moment I don’t have so much time to look into it, but when/if I find a solution I will post it here!
I Think I will try contacting the support about this question.
Unfortunately not. At the moment I don’t have so much time to look into it, but when/if I find a solution I will post it here! I Think I will try contacting the support about this question.
Posted: 1 decade ago 12 juin 2012, 10:29 UTC−4
Thanks.
Thanks.
Posted: 1 decade ago 11 juil. 2012, 10:00 UTC−4
any update about this problem? I am also interested in changing the value of one variable before doing the next step in a time step simulation.
Hi, any update about this problem? I am also interested in changing the value of one variable before doing the next step in a time step simulation.
Posted: 1 decade ago 30 juil. 2012, 02:18 UTC−4
No progress yet, unfortunately. I have been on vacation and in August I will not have so much time to look into this, but hopefully in September.
