AC
Please, how to bring highfrequency AC to the capacitor plates?
3 Replies Last Post 16 avr. 2012, 12:15 UTC−4
Posted: 1 decade ago 16 avr. 2012, 11:35 UTC−4
for example if you solve in frequency domain (harmonic development of the equations) then you set the amplitude in the BCs and the frequency freq in the solver settings as an unique or a range of values.
Note, take care to respect the ACDC conditions, frequencies sufficient low such that the wavelengt is much bigger than the domains you measure on, else you should use the RF module for "really" high frequencies GHz or optical
Check the doc and the model library too ;)
Hi for example if you solve in frequency domain (harmonic development of the equations) then you set the amplitude in the BCs and the frequency freq in the solver settings as an unique or a range of values. Note, take care to respect the ACDC conditions, frequencies sufficient low such that the wavelengt is much bigger than the domains you measure on, else you should use the RF module for "really" high frequencies GHz or optical Check the doc and the model library too ;) -- Good luck Ivar
Posted: 1 decade ago 16 avr. 2012, 12:14 UTC−4
Hi Ivar,
thanks for your reply. Please, I describe my problem in subject Diathermy heating.. Is it possible to use RF module?
Hi Ivar, thanks for your reply. Please, I describe my problem in subject Diathermy heating.. Is it possible to use RF module?
Posted: 1 decade ago 16 avr. 2012, 12:15 UTC−4
Sorry, It´s Shortwave diathermy subject.
www.comsol.eu/community/forums/general/thread/27817/
Sorry, It´s Shortwave diathermy subject. http://www.comsol.eu/community/forums/general/thread/27817/
