How to calculate the radiated sound power only using the structural module and Rayleigh integral?
How to calculate the radiated sound power only using the structural module and Rayleigh integral? I studied the noise radiation of a vibrating plate by using acoustic-structure interaction and PML. However, it is computationally expensive. Therefore, I intend to calculate the radiated sound power only using the Rayleigh integral and compare the results with those of the acoustic-structure interaction. Is there a module to use Rayleigh integral in COMSOL? Or do I need to post-process the FEM result manually? Thank you in advance.
0 Replies Last Post 4 févr. 2021, 11:36 UTC−5
Hello 良云 王
