What's better for COMSOL fluid and temp sims: a new laptop or an old server?
Here are the relevant specs:
HP Laptop 15-dy1xxx:
Intel(R) UHD gpu, 12 GB of RAM (non-upgradable) DDR4, 2666 MHz, 4 cores, 1.3 GHz clock rate (max is 4.0 GHz), HP 86C9 motherboard, Intel Core i5 10th gen. Released around 2017.
IBM/Lenovo x3850 x5 server:
Nvidia Grid k1, 64 GB of RAM (DDR3, 1333 MHz), 32 cores, 2.0 GHz clock rate (2.3 GHz max), Intel E7-4830 processor (quad core). Released in 2010.
I'm planning on doing fluid simulations and a few temperature simulation on the chemical end (physical properties like viscosity).
Any advice?
3 Replies Last Post 28 janv. 2021, 14:08 UTC−5
Posted: 3 years ago 28 janv. 2021, 13:18 UTC−5
Well, your old server has more RAM and more cores. See https://www.comsol.com/support/knowledgebase/866 for Comsol's view.
Posted: 3 years ago 28 janv. 2021, 13:50 UTC−5
My concern is that it's much older. Will the older, slower cores and older, slower RAM be an issue?
>Well, your old server has more RAM and more cores. >See https://www.comsol.com/support/knowledgebase/866 for Comsol's view. My concern is that it's much older. Will the older, slower cores and older, slower RAM be an issue?
Posted: 3 years ago 28 janv. 2021, 14:08 UTC−5
Updated: 3 years ago 28 janv. 2021, 14:08 UTC−5
Sure, older is slower! But if you start running out of RAM and then have no choice but to rely on the slowest incremental solvers (to reduce the required RAM), and/or swapping memory out to disk, then you will run enormously slower! (Been there, done that.)
Best Solution: Persuade your sponsor/customer to pay for a really powerful, modern workstation loaded with everything you need. :)
Sure, older is slower! But if you start running out of RAM and then have no choice but to rely on the slowest incremental solvers (to reduce the required RAM), and/or swapping memory out to disk, then you will run *enormously* slower! (Been there, done that.) Best Solution: Persuade your sponsor/customer to pay for a really powerful, modern workstation loaded with everything you need. :)
