Evaluating a E-Field from a sinusoidal B-Field in comsol
I'm currently learning Comsol 4.2a and would like to evaluate the E-field of a system when a sinusoidal B-field is applied to the system. I can currently apply a B-field to the system using the MFNC toolbox in the time domain but this tool box has no method of evaluating the E-fields.
To induce a E-field from a B-field this needs to be done with a time- changing B-field, this why i have done this simulation in the time domain and the B-field is defined by the sinusoidal function at a frequency of 1kHz.
I did try to overlap physics toolboxs, and using the MFNC toolbox to apply the B-field and then applying a MEF toolbox to evaluate the E-fields but i do not get a answer. Does the MEF toolbox need a input? and if this is need how do I input the B-field in this toolbox?
Can the E-fields be evaluated in comsol from a time changing B-field?
0 Replies Last Post 10 avr. 2012, 06:39 UTC−4
Hello Larry Schmidt
