2 avr. 2012, 10:30 UTC−4
Would something like this do what you want?
Cheers
Edgar
Cheers
Edgar
2 avr. 2012, 11:59 UTC−4
Thank you Edgar,
Unfortunately I'm still using 4.2 (maybe this is the problem?) and it wont open that file. It's quite a challenge to update it on the cluster I'm using here but I'll give it a go. I'll get back to you in time if I have any success...!
Thank you!
Thank you Edgar,
Thank you!
3 avr. 2012, 06:34 UTC−4
Sadly it looks like the update is going to be a next to impossible task. Would it be possible to take a screenshot of the model builder tree for me to see the structure of how you've created yours?
Thank you so much.
Thank you so much.
3 avr. 2012, 07:43 UTC−4
Here is the screenshot. I assembled those 4 domains, all are copper. This way I could set the internal boundary to insulation. Left and right boundary are set to 1V potential and ground. The other internal boundaries are continuous as default.
Cheers
Edgar
Cheers
Edgar
3 avr. 2012, 08:03 UTC−4
Okay great, thank you!
This will be a good starting point though eventually I'd like to model some random cracking and cavitation in my material so I don't think I'd be able to tessellate very large numbers of shapes in this manner.
I'm currently experimenting with using very large aspect ratio rectangles (100:1) and setting an electrical insulation boundary condition on them. It seems to be functioning though I had hoped that the suggested update in 4.0a would make this easier. I envisage that with the small size and large number of 'cracks' (rectangles) I will eventually run into meshing problems with my rectangle method.
