Robert Koslover
Certified Consultant
4 years ago
17 déc. 2020, 13:37 UTC−5
Updated:
4 years ago
17 déc. 2020, 13:39 UTC−5
First, excuse me for not fully understanding your field. You mentioned a square wave. But you also mentioned "a global equation equal to 2pift." That notation would seem to imply some kind of sinusoidal wave, with an angular frequency omega = 2pif. I have no idea why that would be relevant to a square wave model. You also refer to a "frequency" of 100 Hz and pulse width of 100μs. A sinusoidal wave (which is what one would normally be talking about, if using "Hz" as a unit) of 100 Hz has a period of .01 second, which is much longer than 100μs (so one could never fit a 100 Hz sinusoidal wave into a 100μs pulse). So, I'm guessing that by "100 Hz" you actually meant to refer to a pulse repetition rate. That is, you have a train of square pulses that are each 100μs wide, at 100 pps (pps = pulses per sec). Right? Ok, let's assume that. Next, I see you are using a time-step of 0.1 sec. If so, that is potentially a big problem. After all, you can't possibly resolve (in time) any detailed physics that occurs during a 100μs pulse if using a 0.1s timestep! In general, time steps have to be short compared to the time scales of the time-dependent behaviors in your model. I suggest you post your model to the forum so that others may review it and offer more detailed assistance.
First, excuse me for not fully understanding your field. You mentioned a square wave. But you also mentioned "a global equation equal to 2pift." That notation would seem to imply some kind of sinusoidal wave, with an angular frequency omega = 2pif. I have no idea why that would be relevant to a square wave model. You also refer to a "frequency" of 100 Hz and pulse width of 100μs. A sinusoidal wave (which is what one would normally be talking about, if using "Hz" as a unit) of 100 Hz has a period of .01 second, which is much longer than 100μs (so one could never fit a 100 Hz sinusoidal wave into a 100μs pulse). So, I'm guessing that by "100 Hz" you actually meant to refer to a *pulse repetition rate*. That is, you have a train of square pulses that are each 100μs wide, at 100 pps (pps = pulses per sec). Right? Ok, let's assume that. Next, I see you are using a time-step of 0.1 sec. If so, that is potentially a big problem. After all, you can't possibly resolve (in time) any detailed physics that occurs during a 100μs pulse if using a 0.1s timestep! In general, time steps have to be short compared to the time scales of the time-dependent behaviors in your model. I suggest you post your model to the forum so that others may review it and offer more detailed assistance.
