Expressions to plot default physics expression
Francesc-Xavier Borras
How can I see the expressions used to plot the default variables from each physic?
Example:
I am working with the lubricant shell. I have the possiblity to plot the velocity field on a the working surface. The software has no problem in drawing it.
This velocity field varies along the film thickness. I suppose the programe is doing an average between top and lower surface and it is drawing it. How can I see which expression is using to plot it?
0 Replies Last Post 23 mars 2012, 12:06 UTC−4
Hello Francesc-Xavier Borras
