Very Simple Heat Transfer
Posted 22 mars 2012, 17:39 UTC−4 Version 4.2a 2 Replies
As always, I really appreciate for your help.
I have a 3D simulation using "Heat Transfer in Solids". It's a extremely simple simulation. I attach mph file.
What I did is applying power to the1-microliter of water to see how much the temperature rises. (10ncal energy (which is 42n Joule) to water for a certain period of time)
1. In Global Definitions, I made "Rectangle" function. (From 0.1 to 0.2 second, 0.1 second period)
2. And then I define a "pulse" in variable under model. Then I simply use "Heat Source" to apply TOTAL POWER in "Heat Transfer in Solids".
3. And the result shows 7.15 micro Kelvin of water temperature, which is quite different from the simple calculation. (Q=m*c*delta T)
4. To confirm the result, I increase time period into 0.2 second and half the power to apply the same energy to the water. (Since Energy is Power times Time.)
5. But the result shows about 9.16 micro kelvin which is very similar with the calculation.
6. So I changed the time period into 0.3, then the result goes back to 7.15 uK.
7. When I changed the time into 0.4 second, then the result shows 9.16 micro Kelvin.
I cannot figure it out. Please let me know what you guys think.
2 Replies Last Post 23 mars 2012, 13:23 UTC−4
