Inlet and outlet boundaries - Concentric cylinders
Posted 29 sept. 2020, 00:47 UTC−4 Fluid & Heat, Computational Fluid Dynamics (CFD), Microfluidics 0 Replies
Hello all,
I have two concentri cylinder with two gases flowing in each cylinder. I was able to specify the inlet boundary conditions for both of the cylinders but I wasn't able to specify outlet conditions for the inner cylinder (says not applicable). I looked at the solution after solving and didn't see any out flow from the inner cylinder. Thanks for reading! Any suggestions are appreciated!
Hello VD
