HELP ME
I HAVE TO DESIGN A MODEL FOR LITHIUM IRON PHOSPHATE BATTERY . SO I NEED THE ELECTRODE MATERIAL LiFePO4. IS IT AVAILABLE IN MATERIAL LIBRARY OF COMSOL 4.2
1 Reply Last Post 14 mars 2012, 02:52 UTC−4
Posted: 1 decade ago 14 mars 2012, 02:52 UTC−4
the easiest is to go on the web to find the material data and then create your own material data node. This allows you to update it regularyl as you learn new things about it. You can start at wiki, but there are other places too, and the best is still scientific articles, that you should be able to obtain via your library
Hi the easiest is to go on the web to find the material data and then create your own material data node. This allows you to update it regularyl as you learn new things about it. You can start at wiki, but there are other places too, and the best is still scientific articles, that you should be able to obtain via your library -- Good luck Ivar
