Prestressed frequency analysis is not supported in Beam interface
when I analyze a shell-truss-beam coupling system by 5.5 version, a error always appearred as 'Prestressed frequency analysis is not supported in Beam interface'. but if I use 5.4 version to analyze this problem, the error will not appear. Do you have any ideas about this? Thanks very much for your help.
Lin
3 Replies Last Post 10 juil. 2020, 04:22 UTC−4
Posted: 5 years ago 8 juil. 2020, 07:10 UTC−4
It was never possible to take prestress effects into account in the Beam interface, but there was no warning message before.
Henrik Sönnerlind
COMSOL
Posted: 5 years ago 9 juil. 2020, 04:05 UTC−4
Dear Henrik, thank you very much.
I want to get the natrual frequency of a coupling system. This system includes beam, truss and shell. Acturally, prestress effects the truss obviously, but not beam. So I am trying to run the study of frequency domain, prestressed for the whole system. Then, there is a error messsage ' Prestressed frequency analysis is not supported in Beam interface. ' Would you share any ideas for getting the frequency of the whole coupling system? Thank you very much for your help.
Lin
Dear Henrik, thank you very much. I want to get the natrual frequency of a coupling system. This system includes beam, truss and shell. Acturally, prestress effects the truss obviously, but not beam. So I am trying to run the study of frequency domain, prestressed for the whole system. Then, there is a error messsage ' Prestressed frequency analysis is not supported in Beam interface. ' Would you share any ideas for getting the frequency of the whole coupling system? Thank you very much for your help. Lin
Posted: 5 years ago 10 juil. 2020, 04:22 UTC−4
Updated: 5 years ago 10 juil. 2020, 05:17 UTC−4
Hi Lin,
The scenario which you outline here (where beams are present in a larger structure, but are not important from a prestress point of view) is of course meaningful.
There is no way to get past the error message in version, and it should not be possible, since we cannot guarantee that the results will be correct, even in your scenario.
In the future, the fact that beams are present in the model should generate a warning, not an error. One of our developers is looking into this. It is, however, not just a matter of changing the message. It must also be ensured that the stiffness matrices generated for the beams are not wrong.
If you send your model to support, it may be possible to find a workaround.
Henrik Sönnerlind
COMSOL
Hi Lin, The scenario which you outline here (where beams are present in a larger structure, but are not important from a prestress point of view) is of course meaningful. There is no way to get past the error message in version, and it should not be possible, since we cannot guarantee that the results will be correct, even in your scenario. In the future, the fact that beams are present in the model should generate a warning, not an error. One of our developers is looking into this. It is, however, not just a matter of changing the message. It must also be ensured that the stiffness matrices generated for the beams are not wrong. If you send your model to support, it may be possible to find a workaround.
