Running Cluster Sweep from the command line on several nodes
I want to use Cluster Sweep with setting After Sweep / Output to file. When I use the following command:
comsol batch -batch off -inputfile model.mph -batchlog model.log
it computes all six cases defined in Cluster Sweep but one by one. It starts with the first one and it computes it in distributed mode using 6 nodes. Then it start the second one etc. But I want to run case 1 on node 1 and case 2 on node 2 etc. in parallel. Like after checking Distribute parametric sweep in Cluster Computing. When I use this:
comsol batch -batch off -nn 6 -nnhost 1 -f nodes.txt -inputfile model.mph -batchlog model.log
it says Settings for Batch 1 are ignored in distributed mode in the log file and it saves only one result into the inputfile and it does not generate batchmodel__.mph files. I know I can use Cluster Computing + Parametric Sweep but I would prefer Cluster Sweep to have every computed case saved separately because the result files will be huge.
0 Replies Last Post 7 juil. 2020, 11:08 UTC−4
Hello Michal Pohanka
