ECAD Import Sweep?
I'm running batches of a piezoelectric, frequency domain simulation over a dozen or so structures which are in part generated externally and imported to COMSOL as .gds files through the ECAD Import module. The files are similar enough that I can use the same geometry and meshing sequences for each import, but sweeping large batches of these files quickly becomes tedious as I have to import each .gds by hand in a separate study/file.
Is it possible to give COMSOL a list of multiple .gds files I want it to import and sweep these in one study? The imported geometries are different in small but non-trivial ways (i.e. I cannot just sweep a length contraction parameter to similar effect.) I'm currently running COMSOL 5.4.
Thank you, Alec
0 Replies Last Post 8 juin 2020, 14:48 UTC−4
Hello Alec Emser
