Surface Roughness- B parameter
Posted 1 juin 2020, 12:28 UTC−4 Computational Fluid Dynamics (CFD), Microfluidics Version 5.5 0 Replies
Hello, I am currently trying to simulate surface roughness on the walls in my microchannel, and have read on several forums that the B parameter in the Turbulent Flow k-epsilon physics in the CFD Module can achieve this.
I have found that the default value is 5.2 corresponding to smooth walls, and was wondering what is the correlation between the B values and real-life measurements (cm,mm,nm etc)?
Hello Rachel Zhang
