Count Elements on Surface
When meshing, comsol spits out the total number of elements contained in the mesh. Is there any way to extract the number of elements on a single surface? I tried to look into the post-processing "Derived Values" section but couldn't find anything.
4 Replies Last Post 6 févr. 2012, 04:44 UTC−5
Posted: 1 decade ago 4 févr. 2012, 05:17 UTC−5
Is it going to do any good ?? if i have not mistaken ... anyways .. just see the image !
PS:
sry i am poor in paint ... nvm !
Is it going to do any good ?? if i have not mistaken ... anyways .. just see the image ! PS: sry i am poor in paint ... nvm !
Posted: 1 decade ago 4 févr. 2012, 15:44 UTC−5
Hi Melanie,
there is a way, it was mentioned in another post last month I believe but you need to combine the mesh type with a integration by summation
You can also use the mesh statistics on a boundary but that variable you cannot access, the one you create can be made callable
And here is the link to the thread, it was centred on the mesh volume, but you need the count too therein
www.comsol.eu/community/forums/general/thread/25442/
Hi Melanie, there is a way, it was mentioned in another post last month I believe but you need to combine the mesh type with a integration by summation You can also use the mesh statistics on a boundary but that variable you cannot access, the one you create can be made callable And here is the link to the thread, it was centred on the mesh volume, but you need the count too therein http://www.comsol.eu/community/forums/general/thread/25442/ -- Good luck Ivar
Posted: 1 decade ago 5 févr. 2012, 23:51 UTC−5
Sorry for the wrong image i have attached ..
Simply right click on mesh and select statistics and change what you want to select for from the drop down list boxes .. "geometric entity level" and "selection"
Sorry for the wrong image i have attached .. Simply right click on mesh and select statistics and change what you want to select for from the drop down list boxes .. "geometric entity level" and "selection"
Posted: 1 decade ago 6 févr. 2012, 04:44 UTC−5
The image that i intended to attach !
