Duplicate parameter/variable name in piezoelectric material
I'm trying to simulate the piezoelectric activity of a disc subject to side forces, in a dynamic problem. My starting point is a 2D simulation adapted from COMSOL library: the transient roling contact. I added piezoelectric physics and changed the ring to a disc.
The solution does not run and gives the above error for the parameter comp1.V
I'm not sure which parts of the model affect it and how to change properly.
Best, Yonatan
2 Replies Last Post 6 mai 2020, 06:54 UTC−4
Posted: 5 years ago 5 mai 2020, 16:25 UTC−4
You have a degree of freedom (the potential) called 'V' and also a user defined variable (under Definitions called V. Hence the conflict.
Henrik Sönnerlind
COMSOL
Posted: 5 years ago 6 mai 2020, 06:54 UTC−4
Thank you Henrik,
Although after correction it encounters another error - I'll post to support.
Thank you Henrik, Although after correction it encounters another error - I'll post to support.
