3D and axisymmetric in the same model?
I have a problem that I'm solving in 3D with the structural mechanics module. About 95% of the structure is axisymmetric, but the last 5% is not. Is there any way to couple an axisymmetric and a 3D problem? I hope that would make my problem run much faster and with much less memory required. Thanks.
8 Replies Last Post 28 avr. 2011, 05:43 UTC−4
Posted: 2 decades ago 13 janv. 2010, 11:53 UTC−5
The way I can think of is to duplicate your geometry One as a2d axi where you put all the axixymmetric application and the other one in 3d for the 3d application and then defines the proper coupling variable between them
JF
The way I can think of is to duplicate your geometry One as a2d axi where you put all the axixymmetric application and the other one in 3d for the 3d application and then defines the proper coupling variable between them JF
Posted: 2 decades ago 13 janv. 2010, 14:49 UTC−5
you can also use the axisymmetric 2D part to quickly construct your 3D by mesh revolving, but for simplest the model (w.r.t. mesh elements) a 2D axie linked to 3D is better, and you learn a lot about linking geometries, which is important to ba able to simplify complex models
Hi you can also use the axisymmetric 2D part to quickly construct your 3D by mesh revolving, but for simplest the model (w.r.t. mesh elements) a 2D axie linked to 3D is better, and you learn a lot about linking geometries, which is important to ba able to simplify complex models Good luck Ivar
Posted: 2 decades ago 13 janv. 2010, 18:17 UTC−5
Thanks to both of you for your help. It sounds like I can make two models, on axisymmetric and the other 3D, and couple them together. If I understand your suggestions, it looks like keywords would be "coupling" and "linking." Corrections or other keyword suggestions are welcome. Or maybe even better would be a hint on where to find a sample of a model that ties two geometries (i.e. axisymmetric and 3D) in structural mechanics, if it exists.
Thanks again. I'll see what I can dig up, and I might be back with more questions.
Thanks to both of you for your help. It sounds like I can make two models, on axisymmetric and the other 3D, and couple them together. If I understand your suggestions, it looks like keywords would be "coupling" and "linking." Corrections or other keyword suggestions are welcome. Or maybe even better would be a hint on where to find a sample of a model that ties two geometries (i.e. axisymmetric and 3D) in structural mechanics, if it exists. Thanks again. I'll see what I can dig up, and I might be back with more questions.
Posted: 1 decade ago 29 janv. 2011, 13:23 UTC−5
One year later, revisiting the same problem, but with COMSOL 4.1. I never figured this out in COMSOL 3.5, either.
I can define a general extrusion coupling in my 2D model. I can't figure out how to link that up to the 3D model. I have spent hours searching for examples and reading the help on extrusion coupling... seems like one side of the coupling is well covered, but no one seems to mention the second side. I know I'm overlooking something, but it really shouldn't be this hard to figure out.
Thanks...
[QUOTE] Thanks to both of you for your help. It sounds like I can make two models, on axisymmetric and the other 3D, and couple them together. If I understand your suggestions, it looks like keywords would be "coupling" and "linking." Corrections or other keyword suggestions are welcome. Or maybe even better would be a hint on where to find a sample of a model that ties two geometries (i.e. axisymmetric and 3D) in structural mechanics, if it exists. Thanks again. I'll see what I can dig up, and I might be back with more questions. [/QUOTE] One year later, revisiting the same problem, but with COMSOL 4.1. I never figured this out in COMSOL 3.5, either. I can define a general extrusion coupling in my 2D model. I can't figure out how to link that up to the 3D model. I have spent hours searching for examples and reading the help on extrusion coupling... seems like one side of the coupling is well covered, but no one seems to mention the second side. I know I'm overlooking something, but it really shouldn't be this hard to figure out. Thanks...
Posted: 1 decade ago 30 janv. 2011, 04:11 UTC−5
One year later I havent either had the occasion to try it out for my own, but I'm convinced it works (with two coupled models).
I can propose that you follow a COMSOL course :
a) a generic one and ask the question ()provide the demand previously) for the exercice part.
b) Or you organise a specific course at your location (depends how many COMSOL users you are) or
c) you get COSMOL to provide a first example.
I have used the two first cases sucessfully, and a few times proposed the subcontracting of COMSOL for some specific model build-up, unfortunately the latter did not happen, because we were not selected for the project contract, but I'm ready to start again ;)
Hi One year later I havent either had the occasion to try it out for my own, but I'm convinced it works (with two coupled models). I can propose that you follow a COMSOL course : a) a generic one and ask the question ()provide the demand previously) for the exercice part. b) Or you organise a specific course at your location (depends how many COMSOL users you are) or c) you get COSMOL to provide a first example. I have used the two first cases sucessfully, and a few times proposed the subcontracting of COMSOL for some specific model build-up, unfortunately the latter did not happen, because we were not selected for the project contract, but I'm ready to start again ;) -- Good luck Ivar
Posted: 1 decade ago 30 janv. 2011, 09:07 UTC−5
Thanks Ivar. I did #1 last February; my question wasn't answered completely, then my job responsibilities took me away from COMSOL for some months. A very similar problem arose recently giving me the need to couple 2D and 3D geometries. I think that one of COMSOL's biggest features (multiphysics and coupling) could be documented a bit better, allowing one to learn those features when they need rather than arranging and waiting for the next opportunity to take a class.
Dave
Thanks Ivar. I did #1 last February; my question wasn't answered completely, then my job responsibilities took me away from COMSOL for some months. A very similar problem arose recently giving me the need to couple 2D and 3D geometries. I think that one of COMSOL's biggest features (multiphysics and coupling) could be documented a bit better, allowing one to learn those features when they need rather than arranging and waiting for the next opportunity to take a class. Dave
Posted: 1 decade ago 28 avr. 2011, 02:53 UTC−4
what do you mean and how do you defines the proper coupling variable between a 2D and 3D model with comsol 4.1?
best regards
what do you mean and how do you defines the proper coupling variable between a 2D and 3D model with comsol 4.1? best regards
Posted: 1 decade ago 28 avr. 2011, 05:43 UTC−4
hi
like adding more "simple" examples of the extrusion coupling variables ? ;)
Try it on simple examples, once understood it becomes rather "trvial" but I agree it takes time to get to that level, I do not yet feel fully "pro" there either
hi like adding more "simple" examples of the extrusion coupling variables ? ;) Try it on simple examples, once understood it becomes rather "trvial" but I agree it takes time to get to that level, I do not yet feel fully "pro" there either -- Good luck Ivar
