Material Sweep While Changing Study Step
Hello!
I'm trying to calculate electric heat with three different cases and, using these results, expect temperature rise. I want to use three Electric Current physics with Stationary solver and Heat Transfer in Solids physics with Time Dependent solver. These physics are calculated on same geometry but materials of component are different in each physics.
So I want to use 1 Study which contains 4 Steps (3 'Electric Current' Stationary steps and 1 'Heat Transfer in Solids' Time Dependent step), and Material Sweep at the time of changing each Step. I studied Material Sweep with changing Study but I cannot find the way to sweep material with changing step.
How can I apply material sweep when changing step? Thanks in advance.
0 Replies Last Post 7 avr. 2020, 14:02 UTC−4
Hello Soonkyu Lee
