5 janv. 2012, 03:18 UTC−5
try a right click on the "Data Set node" there you can create/extract other data sets from the original, with cuts, etc.
But you have also the Plot slice option in 3D
5 janv. 2012, 03:37 UTC−5
thanks for your reply.
I am not looking for a cut plane, but I'd like to plot in 3D maybe those solution data points where x > 0 to look inside the model.
Best regards
Matthias
Best regards
Matthias
5 janv. 2012, 09:49 UTC−5
If I understand you correctly, you are looking for filters. You can right click on any 2D or 3D plot node and add a Filter node. You can then use a logical expression, e.g. x > 0.1 && z > 0.5 to only include the elements that fullfill the specified condition.
5 janv. 2012, 09:59 UTC−5
Thanks a lot, that was exactly what I was looking for.
5 janv. 2012, 10:26 UTC−5
indeed you have the "filter" sub node, but there is also the cut plane and then export a plane variable as a 3D height plot, there are many possibilities, all depends on what you are looking for ;)
