Velocity input: surface waves
Posted 19 janv. 2020, 23:50 UTC−5 Fluid & Heat, General, Computational Fluid Dynamics (CFD) Version 5.5 0 Replies
I am designing a numerical wave tank using COMSOL to study FSI problem (Fluid structure Interaction, Two phase flow, Phase field) . At present I am using mesh displacement for a moving paddle to generate waves.
I would like to generate waves based on inlet velocity, the inlet velocity need to be defined as a User Defined Function based on orbital velocity of particles in the fluid.
A C++ code is available to determine the inlet velocity, may I know how this can be incorporated in the COMSOL model? Or is there any similar solved problems available for COMSOl?
Dharma
Hello Dharma Sree K K
