Problem with Joule's Heating module
I am getting the following error in the joule's heating module:
Feature: Time-dependent solver1 (Sol1/t1)
Error : Failed to eveluate the variable jacobian
Can you give me a solution for this problem?
Kathir
1 Reply Last Post 20 déc. 2011, 05:27 UTC−5
Posted: 1 decade ago 20 déc. 2011, 05:27 UTC−5
Have you try to verify all the expression used in parameter table, definitions and boundaries of your model ?
Dinh An
Hi, Have you try to verify all the expression used in parameter table, definitions and boundaries of your model ? Regards, Dinh An
