Droplet generated in T-junction disappeared along the channel
Hi, I have been trying to run simulations to generate droplets in t-junction microchannel. I succeeded in generating a droplet(slug flow type) but along the channel, it started shrinking and disappeared completely before reaching the outlet. I haven't seen anything like this before,like if the fluids are immiscible how can a full droplet vanish!!?. Flow conditions-: qc=qd=100nl/min Wetted wall condition with contact angle= -pi/4 surface tension=0.0025
Also, after this simulation, I have been getting lots of '-out' & the following warning in the log window-: "Warning: Problem encountered during results while solving. Unexpected size of render data."
It would be really wonderful,if someone can suggest a solution to fix this problem
0 Replies Last Post 9 nov. 2019, 23:53 UTC−5
Hello Samyak Singh
